04-02-2022 11:06 AM
What do people suggest for add-ons when going down south? Do we only have access to talk time?
Add-Ons
04-02-2022 06:06 PM - edited 04-02-2022 06:07 PM
Download a voip provider such as textnow. Choose a Canadian number. Before leaving Canada call forward your pm number to your voip phone number. If you have a stopover do not let your phone connect to a US tower (keep your phone on airplane mode until you arrive in cuba). Now your incoming calling will ring thru to your voip provider while on WiFi or with mobile data if you get a local SIM card. You can return calls or text using your voip provider.
Here is info in local SIM cards while in Cuba....
https://www.phonetravelwiz.com/buying-a-sim-card-in-cuba-guide/
04-02-2022 11:42 AM
@Violetmwhitney wrote:Will this use the Cuban wifi? Do I register with a Cuban phone number? Or a PEI phone number?
TextNow is an VoIP app that will work on any Wifi or Mobile data. When you join, you get to pick a Canadian phone number and people just all that number like a number phone. For you, as long as you are on wifi/mobile data, when people call you , the app will ring and you talk like a phone
Only thing is that, as long as Cuban does not block it, it will work
04-02-2022 11:41 AM
It's just an app that needs the internet to be useful. So any wifi will work. I would register with a Canadian phone number.
Assuming of course certain countries don't put any limits on internet usage.
04-02-2022 11:38 AM
04-02-2022 11:35 AM
Right. And that add-on is only for while in Canada and it doesn't include Cuba.
04-02-2022 11:32 AM
@norsearts wrote:Every person has different needs while traveling. Length of stay, location of repeaters example dead zones etc. This seems to be a good add on. Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Excellent deal for travel while in US. PM has nothing available for use outside of Canada or USA (with the add-on).
04-02-2022 11:23 AM
I’m going to Cuba…the only thing I found was International talk
04-02-2022 11:22 AM
04-02-2022 11:19 AM
@Violetmwhitney
@hairbag1 wrote:Out of luck...no roaming in Cuba. Try free voip app TextNow which uses wifi. You can call / text most any Cdn or US number using TextNow and your wifi.
Another option is to purchase a local sim and a cheap plan while in Cuba. Take an old, unlocked phone with you. Only trouble with that is...people in Canada won't be able to call your new Cuban number unless they have a long distance calling plan.
The free voip app like TextNow is a good option for you.
04-02-2022 11:17 AM
lol I guess obviously Cuba is south but that term makes me think of southern states. ie. sunny and warm.
04-02-2022 11:11 AM
3G issues are making even the US ones hit and miss, but yes no other options for any other country - so either a local option or voip type app is probably the way to go.
04-02-2022 11:11 AM
04-02-2022 11:10 AM
@Violetmwhitney wrote:I’m not going to the US…I’m going to Cuba
@Violetmwhitney Sorry, you won't get any service in Cuba, PM only has roaming for US and no where else
You will need to buy local Data prepaid SIM and use VoIP app, like TextNow, to make free calls and text
04-02-2022 11:10 AM
@Violetmwhitney Unfortunately PM service doesn't work in Cuba. Only Canada and US (with add ons)
04-02-2022 11:10 AM
Sorry, no international roaming besides USA. You will unable to use Public mobile in Cuba.
04-02-2022 11:09 AM
There is No PM service in Cuba.
04-02-2022 11:08 AM
04-02-2022 11:08 AM
Without any 10 day roaming packages, you are able to only receive texts while in the USA. Not able to send texts, talk or data.
Depends on your needs, you can purchase talk, text and data.
Here is some more information:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
04-02-2022 11:08 AM
Depends for how long. If a week or two then the add-ons aren't a bad deal. If longer then they start to become expensive compared to getting a local service. The add-ons are talk and text and data. Another option is voip apps that work on wifi or data.
04-02-2022 11:08 AM
Only 10 Day US Roaming talk / text / data options. They only work for....10 days (240 hrs)
04-02-2022 11:08 AM - edited 04-02-2022 11:08 AM
Here is a list of all US add-ons
US Roaming for 10 day packages
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
You don't need to purchase US roaming text add-on to receive incoming texts while in US.
Purchasing add-ons is two step process: add funds and then go back to purchase correct add-on. Make sure to purchase the add-on as close to trip date as the clock starts immediately upon buying and is limited for 10 days x 24 hour period.
04-02-2022 11:07 AM
@Violetmwhitney If you go to US, you will need to purchase roaming add-on to use the service. (The only exception is that you get receiving text for free, but you still cannot send text)
Here are the US roaming add-ons, depends on your need, you can buy the one you want:
US Roaming
Bundle - US Roaming - Talk Text (10-day) - $15.00 (10 Reward points)
Bundle - US Roaming - Talk Text 250 Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 1 GB Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 250 MB Data (10-day) - $10.00 (5 Reward points)
Data - US Roaming - 500 MB Data (10-day) - $15.00 (10 Reward points)
Text - US Roaming - Unlimited Text (10-day) - $8.00 (5 Reward points)
Talk - US Roaming - Unlimited Talk (10-day) - $8.00 (5 Reward points)
