From Canada and in US
09-29-2024 11:14 PM
Hi,
I’m from Dieppe, NB, Canada. Right now, I’m in Washinghton DC. I’ve bought bia my rewards (25pts) US Roaming bundle 3G text and voice. Why can’t I use it??? Frustrating!!
Let me know asap
tks,
Rheal
Service
10-01-2024 09:36 AM
this is the link to private messgae:
10-01-2024 09:34 AM
Geezz! I can’t find Private Message????? And I see I’m the only one searching for it. This needs to be addressed! Can you give me the steps where to find it? Or can you give me a direct link?
09-30-2024 05:32 PM
hi @Ralph_71 they usually reply within 2 to 4 hours
keep checking your inbox here for agent's reply
09-30-2024 05:28 PM
I have made a ticket. Tks for your guidance. Hope they will respond!??
09-30-2024 03:48 PM
@Ralph_71 If it's still pending then I would assume that's why it isn't working. Did you definitely have 25 points in My Rewards? If so you probably should contact customer service to find out what the problem is. Open a ticket at the chat icon bottom right of this page or, if that doesn't work, send support a private message using this link
09-30-2024 02:58 PM
Hi,
I’ce checked several times in my Public Mobile, it’s still saying pending.
09-30-2024 12:29 PM
@Ralph_71 Have you logged in to your account to make sure the add-on is there?
09-30-2024 09:05 AM
Is has always been in LTE and Data Roaming is on. Still nothing ?
Is my phone the problem?
09-30-2024 08:50 AM
@Ralph_71 No you don't need a new sim card. Go to Settings - Cellular - Cellular Data Options and turn Data Roaming on and make sure Voice and Data is on LTE and not 3G.
09-30-2024 08:38 AM
I have a iPhone XR.
I have change my subscription from 3G to 4G last month.
I’m seeing option 3G/lTE. So, what I’m seeing is that my phone is locked in 3G mode? I do understand that US is not supporting 3G no more. So now, my question is: why is my phone still locked in 3G?? Do I need a new Sim card?
09-30-2024 07:43 AM
@Ralph_71 Make sure data roaming is turned on and that you are set to 4G/LTE and not 5G. What phone do you have?
09-30-2024 04:22 AM
When did you redeem points for the US Roaming add on? The 15 day "clock" starts as soon as the add on appears in your account which is usually right away. Do you still see the Roaming add on in your account?
09-29-2024 11:35 PM
Here is some more troubleshooting advice:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
09-29-2024 11:24 PM
@Ralph_71 wrote:I’m from Dieppe, NB, Canada. Right now, I’m in Washinghton DC. I’ve bought bia my rewards (25pts) US Roaming bundle 3G text and voice. Why can’t I use it??? Frustrating!!
Are none of voice, text, and data working? Try manually selecting either the A&T or T-Mobile networks to see if that helps.
