Form for a Ticket is not working
Chuckwagon
I need to submit for a ticket to return a certified cell phone within 30 days yet the form in Community will not let me submit? Need help please.
1 ACCEPTED SOLUTION
Accepted Solutions
8 REPLIES 8
BeachNBeer
Yummy
No, ticketing does not work properly.
Send a private message to the CSA - agent by clicking Here
Chuckwagon
Thanks BeachnBeer, appreciate info, I hope it leads to something fruitful.
Chuckwagon
Thanks, I used BeachnBeer link, maybe it is the same thing.
BeachNBeer
@Chuckwagon Yes same link. @Yummy just made it look fancy 🙂
BeachNBeer
@Chuckwagon The link lets you private message Public Mobile workers directly. Keep an eye out on your inbox on these forums. The envelope icon top rightish is your inbox. That's where they will write you back.
rolande-1945
All I got was a go around
HI @rolande-1945   What was the trouble you get?  Unable to open ticket?
If so, message PM support directly if you cannot open via Chatbot
