05-29-2022 11:53 PM
I am not receiving sms on my public mobile phone number. When i sending sms its showing sms sent but the recipient not receiving it . It was all working good in the past . since last 3 days i am experiencing this .Please help me.
05-30-2022 03:00 PM
@manjuwils In case you're not sure how to edit/delete your tel. #, just click the downward arrow top right of your post and then select edt/delete your number from both of your posts. This is a public forum so it's not a good idea to share any personal information here.
05-30-2022 01:15 PM
Yes, i did. Its success ful
05-30-2022 01:13 PM
LG velvet
05-30-2022 01:06 PM
did you try sending text to multiple people and all got the problem? Or just one particular one?
And you are certain you are sending as traditional sms and NOT iMessage or RCS? Check the colour of the text and you can tell:
05-30-2022 01:02 PM
I see you doubled down lol, you should remove your #, do you have an iphone? android? model etc
05-30-2022 01:01 PM - last edited on 05-30-2022 03:08 PM by computergeek541
xxxxxxxxxxxxx
05-30-2022 01:01 PM - edited 05-30-2022 01:01 PM
@manjuwils Please update your post and remove your phone number for your protection This is an open forum.
@JL9 was asking you what type, brand and model, of your phone
05-30-2022 01:00 PM - last edited on 05-30-2022 03:07 PM by computergeek541
xxxxxxxxxxxxx
05-30-2022 06:42 AM
Perhaps performing a Reset of your device's Network Settings will correct your issue.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
If you are an android user, see some troubleshooting found here: https://parsons-technology.com/how-do-i-reset-my-sms-settings-on-my-android/
05-30-2022 01:36 AM
What phone do you have?
05-30-2022 01:12 AM
Check your Settings>Messages>enable iMessages, enable Send as SMS and enable MMS messaging.
Also check Settings>Cellular>enable Cellular Data.
They should all be turned on.
05-30-2022 01:00 AM
When was your renewal of plan. Make sure your payment was successful.
Are other services working? If only sms is working, restart the device and re-seat the SIM card.
