Forget my 4 digit access pin number
Darougar
Hi
I forget my 4 digit access pin number. Please help
HI @Darougar   For PIN reset you  have to open ticket with PM CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Reset PIN"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
dabr
@Darougar   PM may have texted/emailed you the 4 digit PIN when you first activated.  If you're unable to find it, then you need to submit a ticket via chatbot and ask customer support to reset the PIN.  Here's a link to chatbot:  https://www.publicmobile.ca/en/on/get-help
MrSpock
@Darougar Hi you will need a customer service agent for that
you will need to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
