Service agent
Couche
I need to speak to a service agent
2 REPLIES 2
HI @Couche   To engage CS Support, please open ticket:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
However, please share your problem, we are customers like you but we might be able to help.  If it is something we can help, it will be much quicker posting your question here than wait for CS Agent
dabr
@Couche   Two ways to get customer support, first try chatbot and submit a ticket here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Second private message CS_Agent:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
edit:  You can also share your issue and someone on the forum might be able to advise quicker?
