Fido is requesting Public mobile to send a port transfer number transfer request again
Jag007
I missed 90 minute window yesterday to reply to message . Please send the port transfer request again
Fraser_1985
I am having same issue - Fido request has timed out twice….
@eddieO wrote:
If you go into your Public Mobile app, then go to the Account tab, you should find the option to Transfer Phone Number
As the customer already has an opened port request, taking the above steps will fail.   Only Public Mobile can fix this and the customer should be using the chatbot to contact a Public Mobile customer support agent.
Phil_Adelphus
@Jag007  Check your private messages inbox in a couple of minutes and I will private message you a number to call.
eddieO
