Family lost their sim card in Amsterdam
What's the best measure to take when you lose a sim card and you don't want to lose your number? Just cancel it and order a new SIM card and activate with the same number?
Let me know!
Thanks in advance everyone!
Dougiedoug
Easily said and done now e exactly how to do that?
@Anonymous wrote:
So essentially the new SIM will recognize the phone and it would transfer over the number? How would it know to cancel the old sim?
@Anonymous   again, you need to link the new sim via My Account.  Please check the steps above
And not sure if you have setup My Account with the EverSafe id yet.   You need to get the EverSafe setup first, so, you can link the SIM card after
 If you have not created an EverSafe id yet,  you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS.  (Sending the code to email would not be a choice until  EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps,  please open ticket with support and have them to help in this situation:
Private message CS agent at
@Anonymous
Order a new sim card but not to "activate" the sim, instead, you want to link your sim card to your existing account so you can keep the phone number
If you have not done so, you might want to first supsend your service first until you got a replacement sim card:
Login to My Account,  go to Profile page,  click Report Lost/Stolen Phone and click Put my service on hold
(or use this direct link: https://myaccount.publicmobile.ca/en/account/profile/lost-or-stolen-phone)
If you are unable to login as you don't have a phone to receive the 2FA code: On the screen it is expecting you to enter the code, click Didn't get the code? or  Resend code and then choose Send email
Then get a Public Mobile sim card from
Once you got the sim card,  you can update the sim card number from either the PM app or My Account via the browser (After login, remember to resume service first if you have used Lost/Stolen to suspend the service earlier.):
If you are updating via Public Mobile app
login and go to Account page
(If you are unable to login as you don't have a phone to receive the 2FA code: On the screen it is expecting you to enter the code, click Didn't get the code? or  Resend code and then choose Send email)
click Change your Sim card and update your sim card number there
To update it from My Account via the browser:
login My Account to request Change Sim card
Go to Profile page, click on the Pencil besides the sim card number, follow the steps to enter the new sim card number and complete the change sim card request
(or direct link: https://myaccount.publicmobile.ca/en/account/profile/change-sim-number  )
https://myaccount.publicmobile.ca/en/account/profile/change-sim-numberhttps://myaccount.publicmobile.ca/en/account/profile/change-sim-number
After the sim card is updated, wait 5 mins, then reboot your phone and it should be good
Not sure if you lost the phone, if so,  use the FindMy service to locate the phone and try a remote wipe
Apple: https://www.apple.com/ca/icloud/find-my/
                 (how to use: https://www.pcmag.com/how-to/find-a-lost-iphone)
Google: https://myaccount.google.com/find-your-phone
Samsung: https://findmymobile.samsung.com/
               (how to use: https://www.pcmag.com/how-to/how-to-find-a-lost-android-phone)
Grinch
Keep paying your account or suspend it
Buy a new sim
Do change sim in My Account
Insert the new sim in phone.
