Going to Italy
01-07-2025 05:45 PM
I live in Canada and will be going to Italy in March. Is there a plan that I can get to call from Italy back to my family in Canada?
Service
01-07-2025 05:56 PM
Also you can download and use WhatsApp
01-07-2025 05:50 PM
PM only works in Canada and only roams in USA and Mexico. In your case, it won't work which means you'll need to get a sim card in Italy
01-07-2025 05:48 PM
@ConfusedMom In addition to what @Chalupa_Batman wrote, when I travel I use a data sim from Airalo along with TextNow to make and receive calls.
01-07-2025 05:46 PM - edited 01-07-2025 05:49 PM
@ConfusedMom wrote:I live in Canada and will be going to Italy in March. Is there a plan that I can get to call from Italy back to my family in Canada?
Hello @ConfusedMom
Public Mobile only works in Canada US and Mexico. It will not work in Italy. If you're phone can do eSIM, here's an option so you can at least make and take calls when there. https://www.airalo.com/italy-esim
EDIT: If your phone doesn't take eSIM - Amazon
