07-23-2023 01:08 PM
I was trying to open a ticket to contact support and this is what it says. Any solutions?
07-23-2023 08:20 PM
I tried on my end it does it to me too we will have to wait till they fix this part of the site.
07-23-2023 07:54 PM
Hello, can you teach me how to do that please?
07-23-2023 07:39 PM
@cristo1212 - you may want to edit your post to remove the screenshot of your phone number.
ALSO, you should move the picture in your profile from your PUBLIC folder to your PRIVATE folder.
07-23-2023 05:17 PM
I also needed to open a ticket to make sure that my plan was on promotion for subscribing but it did this to me too, the best way is to wait see if they have updates for the app or on the site and also to look through the rhe app or site ourselves to solve the problems we might need help with as it might be faster and easier than waiting and sometimes having them say that they are only from sales and not technical support.
07-23-2023 02:46 PM
just so's you know...the Community Forum is kinda the 1st line for help with PM issues you may experience. There's a room full of genius's here that are sure to have seen most issues and can provide quick guidance. If your concern is an account problem, only the CSA can address those type of problems for you. Best is to come here first for all your PM related problems. Welcome aboard.
07-23-2023 02:00 PM
weird, I don’t know how but it never said anything about sending me a code or no confirmation. So I’m not sure, but I’m talking to CS Agent and he seems to be helping me transfer it
07-23-2023 01:56 PM - edited 07-23-2023 01:56 PM
@cristo1212 if you are porting from Koodo, it can be ported for sure. The error could suggests a earlier porting attempt was still pending, could be from an incomplete activation . Please message support for confirmation
07-23-2023 01:49 PM - edited 07-23-2023 01:50 PM
@cristo1212 That strange . Did you also check for what it’s worth
Check to see if # can be ported
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
adding the Koodo account is still active correct @cristo1212 ?
07-23-2023 01:47 PM
Hey, when I click transfer phone number, and then type my old number in, it still says not eligible for port
07-23-2023 01:36 PM
@cristo1212 Notice under first red circle . It says transfer number . And only use old providers account number . Don’t use the phone IMEI it’s not needed and causes more issue then it’s worth . Leaving old providers SIM card in phone Koodo still needs to be active so you get confirmation text from Koodo that you want to port number by replying YES to it you have 90 mins to reply
Change # on profile tabs
07-23-2023 01:33 PM
No no, this is post paid number and I’m trying to transfer it here (Public Mobile).
07-23-2023 01:31 PM
@cristo1212 If this is Koodo pre paid you need support to port the number for you if it’s Koodo post paid you should be able to do this in your my account.on profile page . Also check
07-23-2023 01:28 PM - edited 07-23-2023 08:02 PM
The reason for that was it didn’t let me transfer my previous phone number from Koodo to Public Mobile, since it showed me an error saying “ phone number was not eligible for port”
07-23-2023 01:25 PM
I see you ran into an error when opening a ticket for support. What was the reason to open that ticket ? I was thinking that maybe someone here can help.
07-23-2023 01:22 PM
@cristo1212 Please submit ticket with support
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
07-23-2023 01:18 PM
It shows the problem in the picture, I’m not sure what you mean by “nature” but that’s my issue.
07-23-2023 01:11 PM
use direct message:
07-23-2023 01:11 PM
whats the nature of your original problem...maybe someone here can help quicker than CSA can.
