08-27-2022 07:05 PM
When I activated my account I made a mistake putting in my dad's email address but now I want to change it to my email address instead. How do you do this I don't see any options in my account?
08-28-2022 05:30 PM
Just thought I'd update everyone I got my email changed and my password reset afterwards. Thanks for all your help.
08-27-2022 09:28 PM
Here's how it's going so far. Just trying to verify my account with the agent to get the email changed.
08-27-2022 09:26 PM
Cool!
08-27-2022 08:12 PM
@Coco_4_coconuts Yes, you just need both emails to be same to receive any Community rewards by participating here.
08-27-2022 08:11 PM
So far so good. Have you submitted a support ticket yet?
08-27-2022 08:07 PM
Thank you. We created this community account with my email the one we're going to use to change to on my self-serve account. Is that the right way to do it?
08-27-2022 07:46 PM - edited 08-27-2022 07:46 PM
@Coco_4_coconuts Just to add to what's already been said, once you've got your email changed for the self serve account, make sure to also update the email address in your Community account to the same email, which can be done by clicking your avatar and selecting My Settings, to receive any community rewards if eligible.
08-27-2022 07:22 PM
Thank you everybody for the quick answers.
08-27-2022 07:18 PM - edited 08-27-2022 07:19 PM
Here are some shortcuts when using Simon the chatbot if you find him a little frustrating to deal with like I do!
Edit:
This is the one you need to change your email address:
08-27-2022 07:13 PM
you need to contact customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type request email change
2. alternatively you can private message them here
08-27-2022 07:11 PM
@Coco_4_coconuts to make email address change, you need to open ticket with PM support to get them to help charging
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
