09-05-2023
07:04 PM
09-05-2023
07:06 PM
computergeek541
Bought a sim card and can't get past activation after e-sim did't work.
09-11-2023 01:27 PM
Yes can turn the 5G on with it. Android version 13 and NetMonitor 1.19.5 (353) I just downloaded it off Google Playstore last night
09-11-2023 09:09 AM
@sheldon_pro you still able to use NetMonitor to turn on? some said it is not working since the update
what Android OS you have? and which version of NetMonitor you have?
09-11-2023 08:34 AM
So I found a way of being able to turn on 5G using the NetMonitor App. on Reddit.
Download NetMonitor then go to settings in NetMonitor (3 dots bottom right), then hit service menu and change it from LTE only to NR/LTE/GSM/WCDMA. You should have 5G back. Works on all Samsung devices and all versions of Android and OpenUI.
09-08-2023 08:29 AM
if you are interested to try reload a different firmware @mtbman has a solution here, at least it works on his S20 Ultra 5G
09-08-2023 02:09 AM
What phone and model is it? If it's a Samsung S20 series then it will not work on Public Mobile or Koodo 5G networks, as this is what I was told from Customer service. But it may work with different providers he said. This is just crazy considering Koodo is still selling S20 series phones and advertising them as 5G compatible.
Good Luck.
09-08-2023 02:01 AM
So this was the outcome and conclusion of the problem I have, Received this back from Customer service. That is correct, it does, your phone has 5G. I meant that the 5G feature does not work with Koodo or Public Mobile due to older firmware limitations. But it may work with other service providers.
09-07-2023 01:12 AM
@sheldon_pro- You have the SM-G981W model. That's slightly different from the excellent guide that talks about their SM-G988W. Make sure to use your specific model...as the instructions say. Just make sure.
09-07-2023 01:02 AM
Follow the procedure word for word with no deviations and you should be fine.
I showed my pictures of the end result and the box my phone came in.
I can only show you the door; it is now your turn to open it.
09-07-2023 12:19 AM
You should be worried. It's very nerve-wracking doing it the first time. I haven't verified those exact steps for any gotchas but it all looks very familiar from when I did a firmware change on my Samsung a couple years ago. It's an excellent reference.
09-07-2023 12:12 AM
So it ends up that PM and Koodo 5G service will not work on S20 phones even know it is a 5G phone, says the PM Customer service agent. That just sounds weird to me. If I do your fix will it work on PM 5G you think? I am just worried about bricking my phone lol...
09-07-2023 12:11 AM
09-06-2023 05:13 PM
If you follow my procedure, you will unlock both "5G" and the "esim" capabilities.
09-06-2023 02:56 AM
It's SM-G981W it says it's 5G on box and as soon as I boot the phone 5G shows.
09-06-2023 01:38 AM
Yes you are correct but it depends if it was made on February 11/20 was without 5G and re-released on March 06/20 with 5G.
I forgot to ask which model number it was.
09-05-2023 10:19 PM
Yes that's what PM site here says as well when i put in my IMEI number but i called Samsung and they said the Canadian versions of the S20 are not e-sim compatible but they are 5G compatible.
09-05-2023 10:17 PM
Follow this:
Good luck!
09-05-2023 10:12 PM
This is not technically accurate. S20-series can run both esim and "5G".
09-05-2023 10:05 PM
I have been waiting for service agent for about 3 hours now and no reply or help yet.
09-05-2023 08:40 PM
I need similar help for a new plan that I subscribed for my daughter
09-05-2023 08:28 PM
Sorry, 5G are available for Samsung S21 or newer.
Just wait for a CS_Agent to get back to you.
09-05-2023 08:07 PM
Samsung S20
09-05-2023 08:05 PM - edited 09-05-2023 08:08 PM
What is the make and model of your phone?
Depending on how busy the agents are. They will pm you back up to 2 hours. Keep your eyes on the envelope icon.
09-05-2023 08:05 PM
2 - 4 hours is usual. Watch the little envelop icon on top right side of this page will be highlighted when they respond.
09-05-2023 07:47 PM
Could you tell me how long it takes for the CS Agent to reply back to me?
Thanks
09-05-2023 07:12 PM
Thanks
09-05-2023 07:06 PM - edited 09-05-2023 07:12 PM
@sheldon_pro wrote:Bought a sim card and can't get past activation after e-sim did't work.
I susepct that you're gong to to need to contact a customer support agent to see if they can change this to a physical SIM activation. Please use the chatbot to open a ticket.
If the chatbot show an error message while trying to open a ticket, please send a private message to CS_Agent.
