02-06-2025
11:41 AM
02-06-2025
11:53 AM
computergeek541
Hello,
I'm trying to either get the e-sim activated or get my money back. I need this to be resolved as soon as possible. As I thought once you buy and e-sim at the beginning and it did the test with your IMEI to see if it was compatible it would automatically activate after purchase. Please either give me a refund or activate the e-sim.
02-06-2025 12:02 PM
HI @Time_03
you can use the same link to contact support and discuss refund option
02-06-2025 12:00 PM
Hi,
It's Android phone. At this point I'm over it. How can I get a refund?
02-06-2025 11:49 AM
hi @Time_03
iPhone or Android?
Check your Sim Manager or Settings->Cellular and see if the Public Mobile esim is already there. Sometimes the error just means it cannot set the esim active. If it is there, enable it, or toggle on "turn on this line" and set as Primary if it is an iPhone
if same, PM support agent can help, , you can submit ticket by direct message:
