02-07-2025
07:51 PM
02-07-2025
10:06 PM
computergeek541
I log into app to complete esim activation and it says phone not compatible, Iphone15pro.
I need a solution or refund
02-08-2025 03:41 AM
Did the eSIM setup work? That was my issue when I got my phone.
02-07-2025 09:14 PM
02-07-2025 09:03 PM
you might not need a refund. Some said it is just an esim setup on the phone problem and not really incompatible. Go to the phone's Sim card manager and check if the esim already instead. If it is, then it is good news. You will just need to enable it and Reset Network Settings
but if you don't see the esim, then you really need PM to check (or ask for refund if you like). Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here
02-07-2025 08:11 PM
@thisistoomuch wrote:I log into app to complete esim activation and it says phone not compatible, Iphone15pro.
That is odd. Please contact a CS Agent to fix this.
You can submit ticket by direct message:
