@edinez Yup, it is frustrating that time is missing in the downloaded version of the usage history. Some members voiced that concern, just not sure if it is on PM's to-do list
For now, if you really need the time for a particular entry, you have to go back and check the web version
And a reminder, the filter has glitch too. You cannot just load the page and run filter, it will only filter you with 2 weeks of info. If you have something more than 2 weeks, you have to click until you reach that date , then apply the filter. Weird glitch
