9 hours ago
My wife's PM plan (30-day, 250MB) does not appear to have had its data usage reset at the start of the 30-day cycle. The "Usage History" claims that 176.37MB has been used but the Usage History only shows 71.85MB used. That's about 100MB that has vanished! I had this happen to my plan, too, a while ago. I don't know how many other times it has happened to us or others, but this needs to be addressed.
4 hours ago
So, another user DM'ed me and suggested that I put the phone into airplane mode. Once I did that, magically, 100MB vanished from my usage, so there is fairly close agreement between the daily data usage records and the plan's usage-so-far info.
8 hours ago
Using a Private Browser window didn't help so I have just direct-messaged customer support.
9 hours ago
@ESP666 yes, quite annoying as you have to refresh yourself sometimes 🙄. Hopefully it will be corrected in the next few updates?.....
Clear cache and sign in again. Or if using the app, drag the screen from the top a few times.
9 hours ago
if you are using app, drag the screen down for refresh. if you are using browser, use Incognito mode
9 hours ago
hi @ESP666
t could be just a browser cache problem. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
