CAN-US-MEX Subscription
Al_from_VAN
Hello. I have a Can-US-Mex Subscription and was wondering the following:
1) if I am in the US, can I make a call to Mexico (and vice-versa) under my subscription, or is it only local calls I can make (US->US, Mex->Mex)?
2) With my subscription, I get unlimited texting ... am I able to text someone in the UK while I am in the US or Mexico, or can I only text Canada, US and Mexico?
Thanks so much, Al
7 REPLIES 7
Ok thanks. 🍻
@hairbag1 wrote:
I think that as long as you have a Canada / US / Mx plan, you can sms to anywhere on this planet, while in Canada, US or Mexico.
@hairbag1 That sounds more reasonable. Thanks
@kb_mv wrote:
@Sansan wrote:
For texting, you have to be in Canada to text out to any other countries that's not Mex, US and Canada.
@Sansan For real?
@Sansan For real?
hairbag1
@Al_from_VAN
hey Al...I'm in Mx right now and wife has the Canada /US / Mexico plan. I can confirm that plan works seamlessly here. These plans are a great addition to the plan menu, especially for US / Mex bound, Canadian snowbirds. Just be aware that when you get home, you likely won't be able to downgrade to cheaper plan.
Sansan
@Al_from_VAN  the plan will work for all 3 countries as if you in Canada. Roaming must be enabled, best to set to manual connection and not automatic.
That being said, it depends on your phone.  It must have VoLTE and be on Public Mobile's whitelist to make phone calls outside of Canada.
https://www.publicmobile.ca/en/bc/get-help/articles/volte
slusagm
1. yes calls within the 3 countries are included
2. yes , can text other countries when you are in US and mex as well
