Double charged for $5 add on
Namu
I just checked my credit card statement and I was charged 2 times ($5.60) for my $5/500 min add on. How do I get this fixed?
1 ACCEPTED SOLUTION
Accepted Solutions
@Namu
Contact customer support via the chat bubble at the bottom right corner of your screen and type "account related issue" and "human" and follow the prompts to submit your ticket via Simple--Simon. Keep an eye on the envelope icon at the top right corner of your screen next to your avatar for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times.
Alternatively you can send a private message via the link supplied previously. It's easiest to ask for a credit to your account. You may be asked to provide a screenshot of your credit card statement showing the extra charge.
15 REPLIES 15
darlicious
@Namu
Can you log into your account and check your account balance? Do you have an extra $5 showing?
@Namu  did you login to your My Account and confirmed you got 2 Add-ons in your My Data & Add-ons?
If that is the case, it's an honest mistake, you can open a ticket with PM to get one of them refunded.   click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  • type: Contact CS Agent
  • Click "Contact Us"
  • Click "Other"
  • Click "Click here to submit a ticket"
  • you will then direct to another page to open ticket.
HALIMACS
Did you purchase the add-on twice, @Namu
If you view your Data and Add-ons, is there one or two line items?
You might be seeing the credit card statement showing both a "Pending" and a "Posted" charge.   If so, the pending will 'fall off' after a few days.
@Namu
sign in to Self-Serve, to review your account, if you found at Available Funds: $$ has the amount left, leave it for next bill cycle the will take it from there automatically,
or you need to  Contact Customer Support Agent by CS_Agent ,and Explain your issue to
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
    Click here to submit a ticket↗↗.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • phone number,
  • account 4 digit pin,
  • Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck..
Namu
The credit card charges are from over a month ago. My transaction history shows a top up of $5 and the talk booster.
@Namu
Is it possible you're viewing your transaction history on the Public Mobile self-serve site?
Plan charges are broken into 2 components there under the Debit (Charges) section:  the '30-day plan' (basically the talk&text portion) and the 'data' component.   It may cause you to be thinking you're being charged twice but maybe you're not.
View the Credit (Payments) column of the Payment History to see what payments were applied.
@Namu
@Namu Can you post the transaction history since the day you top up the $5?  it could be you loaded $5 twice but one of the $5 gone to buying of the add-on and the other one left there for the plan renewal after.  Would be helpful if we see those transactions to confirm
Namu
I may be a senior but I know the difference between my online credit card statement and my public mobile account. I did originally post that I checked my credit card statement to find the 2 charges of $5.60.
