02-09-2025
05:13 PM
02-09-2025
09:05 PM
computergeek541
02-09-2025 05:21 PM
hi @Loose_ends
do you request any change now plan change
Go to my account , payment history to confirm how many times PM. charged you, or post a screenshot so maybe we can explain
or if you like you can check with PM support directly
submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
02-09-2025 05:18 PM - edited 02-09-2025 05:20 PM
@Loose_ends wrote:I usually get charged 28$x2 but I was charged 28$x2 + 16$ x2 also????
Hello @Loose_ends
First, log into your account and then click on this direct link. It will show you what you were charged. And if it's a wrong charge, contact a CS Agent.
https://myaccount.publicmobile.ca/en/account/payment/payment-history
You can submit ticket by direct message:
