Overcharged
Dikfour
I upgraded to a $30/month plan which I was charged for.   The upgrade plan tab shows that I’m still getting the lower cost plan but paying for the higher plan.
2 REPLIES 2
HI @Dikfour
it could be just a browser cache problem.  Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with PM support agent.  You can submit a support ticket right at My Account and PM app using the  Expert Messaging in one of these ways:
  • My Account on a browser: Login and click Message Centre on the left pane to Start a Chat
  • Public Mobile App : Login, and Go to Support page, click Chat with an Agent, and Start a chat
  • If unable to access My Account/PM app, submit a ticket here using the your current Community login (or use another email to create a new Community account):   https://expert-messaging.publicmobile.ca/guest/chat/
    At the Chat, type "Submit Ticket", then type "Connect Agent", and type "Connect Agent" again.  Then login to open ticket
    (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email" or "Send Voice Message")
Support agent will reply within 2 to 4 hours.  You will be notified via SMS/email or monitor here:
Remember: Support hours of operation: 9 AM to 10 PM ET
Can you try again using private mode on your browser or using the Public Mobile app.
You can reanc a agent with expert messaging if it still shows the old plan.
You can submit a support ticket using My Account or PM app
You can also submit a ticket here using the Community login :   https://expert-messaging.publicmobile.ca/guest/chat/
