02-13-2025
10:39 AM
02-23-2025
12:12 PM
Dunkman
Hi need to get copies of my bill form 2020 2022 2023 2024 when i log on now i dont see anything as i have charged my provider to bell i need a new phone
02-13-2025 10:44 AM
hi @Leahdeagle
PM support agent can help to prepare invoices from those years
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
02-13-2025 10:42 AM
you need PM to help you with that as you can only download the invoices for last 12 months
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
