Does Public Mobile have a traveling subscription?
Taylor9301
I am going on a trip to Asia for 2 months and would like to be able to text and use data to search locations and everything. Does public mobile have plans for international travel or should I get a new sim for this trip? My plan includes international texting but is that just from Canada or is it both to and from?
Also, if I get a new sim can I pause my public mobile plan for those months?
Thanks for any help
hi @Taylor9301 no roaming I'm Asia. But data in Asia is cheap, get local data or travel esim. Then use VoIP app Textnow to make calls on the app using wifi or local data
For PM, you can turn off autopay for 2 months while you are away.
hairbag1
@Taylor9301
just before your flight leaves, log in to your PM acct and disable Subscription (same as Autopay). After your current subscription expires and renewal fails to occur, you'll have 90 days to re-enable Subscription and Reactivate the account....BUT...it's time sensitive...make sure to get the account paid before 90 days in Suspension.
Meow
ONLY service PM provides is for Canada and USA (with add-on or specific plan).
@Taylor9301  .no sorry PM only has roaming in the US . So anywhere else in this wonderful world . You  would be best served to get a local pre paid sim card in your destination . That or choose a company that has roaming around the globe
