Does Public Mobile Offer Mobile Internet? Something like through a tablet or laptop?
Flameotter
Hello everyone,
I'm wondering if Public Mobile has any Mobile Internet plan that could be used in a tablet through an SIM card or USB Dongle or stick for a laptop?
Essentially would be data only probably?
If so, what are the options or are there some work arounds?
Thank you.
glenna1
My microsoft Surface takes a Sim card. I am trying to find out if I can just put phone card in there and use the data. The chat bot just has me going in circles!!
@Flameotter  Bell sells, or at least used to sell, a Huawei turbo stick that took a sim.  Is that the sort of thing you're looking for?
@Flameotter if you have some cannot unlocked mobile internet router that take sim card, yes, you can put the PM sim there and it would work
Flameotter
@softech Is there any way to use a SIM card in a stick or some sort? There are some options that require a USB Modem like TP-Link business routers. The Tethering option works great with GL-Inet Travel Routers, but I am looking for something that would automatically connect once the main internet line goes down.
Thanks.
@Flameotter they don't have data open plan.  But if you need a lot of data for your table, the current $34 plan is as good as many data only plan for tablet out there
@Flameotter  No sorry just data for cell phones but you can hotspot your cellular data to tablet or laptop
