pok code
04-06-2024 02:07 AM
My sons phone is asking for a puk code.
We are trying to log into his account but cant remember the passord.
his account was blocked for one hours for several times now over the last 2 days.
We reset the password by sending the code to the email on file. After reseting the password the system enters a loop where it says the password needs reseting. The other alternative is to send a code to the phone number instead of email. But the phone is not active due to the requirement of puk code.
Can someone help?
Thank yuou
Other
04-25-2024 02:51 PM
What are you trying to do? What was your error message? Did you contact PM? See direct link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-25-2024 02:02 PM
tried this in 3 computers 2 cel phones and several browsers now.
04-06-2024 07:21 AM - edited 04-06-2024 07:22 AM
Admittedly, this reply may be a partial repeat of @Sansan , however if there's additional info which may be useful here, then I offer it for that possibility:
What is the message you're getting?
If you're getting:
"SIM network PIN blocked. Enter SIM network PUK." on a Samsung phone then call Samsung at 1-800-726-7864 and they will give you a code to unlock it. They'll want the IMEI of the phone in question.
If any of these:
- "SIM network unlock PIN"
- "SIM ME lock code NP"
- "SIM not Supported"
- "SIM locked"
- "Network Unlock Code"
- "SIM PUK code
- "Network Control Key"
- "Master Unlock Code"
- "Network PIN",
These mean the phone is locked to a previous provider. You'll need to contact them to unlock the phone.
If any of these:
- "PIN unlock key (PUK)"
- "Enter PUK Your SIM cannot be accessed"
- "Locked SIM"
then contact support:
- Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us, or,
- Send a private message to Customer Support Agent by clicking here. You’ll need to be logged into your Community account for the link to work.
04-06-2024 02:23 AM - edited 04-06-2024 02:24 AM
Could be just error logging into email. Try a different browser or clear cache. If still doesn't work, use the support section to create a ticketbir the chatbot.
Here is some information regarding puk code.
