04-17-2025
10:31 PM
04-19-2025
03:16 AM
computergeek541
04-19-2025 04:14 AM
Note, FYI. PM Esim QR code does not install or activate on 3rd party ADD-ON Esim programs!
04-18-2025 12:26 AM
04-18-2025 12:21 AM
04-18-2025 12:10 AM
did you use the Public Mobile app to activate the account? if you used the app, you don't need the QR code. The app already installed the esim for you.
Can you check your phone's Sim Manager first? or check Settings-> Celluar on iPhone. Check if a Public Mobile esim is there.
04-17-2025 11:06 PM
Ok if its not there, use the chatbot to create a ticket.
Or if you have difficulty use the next link below.
04-17-2025 10:50 PM
04-17-2025 10:46 PM
I did, nothing.
04-17-2025 10:37 PM - edited 04-17-2025 10:41 PM
Did you check your spam or junk folder?
If its not there use the orange bubble lower right to submit a ticket to cs agents for assistance.
