no phone or texting.
WJSouter
hopefully someone can help me.  I made a cell call yesterday successfully. I went to make another call and it comes up couldn't connect.  I still have internet service. WIFI works ok also. This morning my phone rang once. the phone seemed to dropped the call. when i tried to call back it says Couldn't Connect.  I am also not receiving texts.  Would anyone have an idea what is going on. My wife is also with Public Mobile and her phone is working Great.
My phone is a Samsung Galaxy A13  5G
Hubertzh1
Have the same problem this morning, no signal
WJSouter
Just to let everyone now the problem is resolved. I had restarted the phone previously. this time i did a shutdown and the restarted it and **bleep** worked
hi @WJSouter
look like you are not alone.  there seems to be some system issue this morning
which province you are at?
Sansan
@WJSouter  it's too early to tell, but it seems that this is an issue affecting alot of people. It doesn't appear to be just you.
You can try to troubleshoot by resetting your networks to see if that will help.
slusagm
@WJSouter
it might be a problem with the system, many posted problem with voice
