3 weeks ago - last edited a week ago
3 weeks ago
@Blinkeek Is your sim an esim? Otherwise you just take out the sim from the old phone and put it in the new one. Then you should be able to log in.
Deleted.
Deleted.
Deleted.
3 weeks ago
@Blinkeek You would need to contact customer service via the chat icon bottom right of this page or, if that doesn't work, send customer support a private message using this link
Are you just wanting to report the phone missing? If you have another phone handy you can just switch the sim card over (unless it's an esim).
3 weeks ago
Hi @Blinkeek,
please edit your post and remove personal info likes email addresses as this is a public forum viewed by all.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
