08-08-2024
08:26 PM
08-09-2024
12:18 AM
computergeek541
Hi,
Can someone close and delete my account immediately without waiting 90 days?
08-08-2024 08:31 PM
@lontb You can port your number out and it will close the account after you successfully port the number out of PM or get support to remove the credit card info right away . You can disable auto pay but it will take 90 days to close out which you don’t want so there is that .
send direct private message to support .
08-08-2024 08:30 PM
Porting out your number deletes your account immediately.
Otherwise stop paying and 90 days rule applies. Before you do this open a Ticket and ask agent to REMOVE your creidt card info from the file.
08-08-2024 08:27 PM
you going to port your number to new provider ? If so your acct will deactivate as soon as you successfully port out. Otherwise, just log in to your acct and disable Subscribed (Autopay).
