3 hours ago
Hi I need to cancel my plan I have for my daughter how do I do this
an hour ago
Just stop paying your bill. Toggle Subscribe button to OFF.
Remove your credit card info - open a Ticket and ask agent to do that for you.
Port your number to another provide - that deletes your account immediately.
2 hours ago
Hi @Kristywutke
If you are looking to change providers, if you port your daughters number elsewhere, that automatically closes the PM account. The other way is to log into the account, turn off autopay. That too will close it. If you're unable to log in, then you may wish to reach out to a CS Agent to help you reset your email or password if needed.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
3 hours ago
There are various ways to cancel the account.
Once you sign into the account online, slide the Subscribed button in green to off. Should turn red. This will prevent further charges to your credit card. After 90 days of non payment account will be closed.
2. Port your number out to another provider. You would need to sign onto the account to get your account number to provide to new carrier.
if you dont want to port, after non payment of 90 accounts auto closes.
if you have a credit card on file, you can use this link to ask public mobile agents to remove the card #.
