Declined payment
Hortence
Hey guys,
I am trying to pay my phone bill but they won’t accept by card, they say that my bank is the problem but I went and they said everything was fine on their end, they have no reason to block my card or anything. I tried to register the card since it wasn’t but it would even work for it. I’m becoming very annoyed by the whole situation, it’s been going for multiple weeks now, I need my phone for a lot of things. Has this happened to anyone other than me, if so would you describe how the situation.
@computergeek541
That for the clarification, I thought I read a posting that someone mentioned it.
Yeah, you can pay your bill with basically any prepaid card...physical or online card, so that isn't mandatory
@BKNS27 wrote:
@Hortence
Is the information on your CC the same as in your account? Is the name and address registered on your CC same as on your account?
The name and address of the credit card do not need to match the Pubilc Mobile account profile name and address.
@Hortence
HALIMACS
@Hortence
For Updating Credit Card information try the following:
Before logging into your self-serve account, recommend this procedure to avoid the common glitches that sometimes occur with this process:
  1. Clear your browser's cache & cookies
  2. Use incognito mode
  3. Now, log into your self-serve account
  4. Click Payment tab
  5. Select "Manage My Card"
  6. Select "replace card"
  7. Type your address exactly as from your billing statement
  8.  Don't use a space in the postal code
  9.  Use ALL CAPS if necessary
  10.  Type everything, not letting autofill complete any fields
@Hortence   So, you tried to enter the same card on the system multiple time?   At the moment, is there any card registered there?  If so, try to make a payment using the option "Other (enter the desired payment amount)" and manually enter the plan amount.  Try that option instead of Amount Due
If that doesn't work or if you don't have a card registered on the system, then I suggest you to open ticket with PM to confirm no fraud locked is set on the account and see if they can manually register the card for you.  To open ticket with PM:
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
