Data
Toy
I have data available but launching my data connection I cannot get internet access
7 REPLIES 7
gpixel
I'm pretty sure PM has fixed the refresh issue on one's account. I haven't had to use it the last few times I've logged in
@Toy
Try again  incognito mode/private mode or a different device or lap top or simply try refreshing the page when logged in
@Toy   did you get an error saying you need to login to something?  If so, that would be data all used up
If not, you should be good
First login to My Account again using Incognito mode (or Private mode on Safari), check if you really have data left  (as what you check previously could be just reading off old cached page)
Also, make sure you have mobile data turned on
If you are on Android, make sure you didn't have any data limit set.  PM is running on 30 days cycle, mobile data limit is a monthly tracker and the different in cycle data could cause problem
Dunkman
@Toy
More details would be helpful.
Does text and talk work?
Has data worked before ?
What  phone model are you using?
A few basic trouble shooting advice:
Reboot phone
Network reset of phone.
If android phone, check APN settings:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Meow
If you see data available on your account (plan data, add-on on bonus) try to reboot your phone - turn it off, wait a little bit, turn it on.
HALIMACS
@Toy
Check to be sure.   Log in to self-serve AFTER clearing cache and cookies, or opening an incognito or private tab.
Also, tap area highlighted below when logged in:
If data remaining, then try resetting network connections or toggling airplane mode on/off.
Make sure your data switch is toggled on.
@Toy
Is the Cellular Data enabled in the settings of the phone?
Also refresh your browser on your account to see the actual amount of data usage.
