yesterday
Have sim, transferred account successfully from Fizz yesterday, data/outgoing calls working but incoming calls/texts and outgoing texts not working
13 hours ago
It looks like your phone transfer was not completed properly. If you didn't respond YES to the approve the transfer within 90 minutes, it can cause the transfer to get stuck. Not to worry though, I have sent you a direct message with the phone number that you can call to re-trigger the porting process. Please check your messages for the phone number to call. Unfortunately, I am unable to post the number in the community forum.
Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage )
yesterday
I did get a text from the old carrier, and I believe I did press yes. I will contract the porting team, thank you!
yesterday
@devjoga05 - I have sent you the porting number for assistance as this is usually that. Or try a restart of your phone and see if your Fizz sim works.
Please view the number I have sent you here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
yesterday
hi @devjoga05
the port was not done
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
