01-29-2023 12:39 PM
01-29-2023 01:42 PM
01-29-2023 12:45 PM
Log into Self-Serve, under Plan & Add-Ons
At the top right
You can change your plan to your choosing.
01-29-2023 12:43 PM
@Jer93 Log into self serve and do your self
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
01-29-2023 12:42 PM
Log in to the account and click the plans & add-ons tab and click on change plan and select a plan. Use the little orange arrows and choose 4G or 3G up top. Then select change on next renewal. Unless you want more data now. Be aware that there is no pro-rating here if you do that.
