Data
OnePuff
  • My data stopped working and I am getting kissed off why
its been a week almost
says I am active
says I have data
added more even
and nothing
piss poor service
i changed nothing on my phone
fix it
Timer
@OnePuff
call *611 press 3 and you need your 4 digit PIN, to check your data usage, any left you have data. or maybe you use all.
DDM69
The community is made up of customers just like you. Try a not so rude approach if you’re asking for help from us. Thanks
Yummy
Did you check your account to see how much data you still have (if any)?
@OnePuff   What kind of phone do you have?  brand and model?
and only data has problem? voice is all good?
If it is just data, it is likely an APN settings problem.
 Check the APN settings , compare it with those below, update it to match:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
Dunkman
@OnePuff
Sorry to hear about your troubles.
I assume talk and text working?  data worked before?
Which type of phone do you have? iPhone versus Android.
Do you see the data counter in your self service page?
A few basic troubleshooting advice:
1. Reboot your phone
2. Network reset of phone
3. Put your PM SIM card in another working phone. Helps determine whether hardware issue versus PM Service problem.
4. If Android, check your APN Settings.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
