4 weeks ago
I would like to use my rewards to get the 15 days US/Canada 5GB with data reward but it is not showing as an option for me. I was able to redeem it for my wife on her account and am not sure why I can’t do the same. Thank you
4 weeks ago
hi @Weirzy
first, login to My Rewards site using a browser. After you are in the rewards site, use this link to access it directly:
https://myrewards.publicmobile.ca/en/catalogue/ADDON-BDLTD%20-US-T5GB
4 weeks ago
@Weirzy it is a browser cache or app cache problem
Please login again using browser with incognito mode
4 weeks ago
@Weirzy Strange it showing there for me , maybe if your using the website try the app instead see if that helps or vice versa . Worst case senerio you can ask support to help apply it for you also
Public mobile prefers
you use the orange chat bubble bottom right of screen . If that dosent work you can instead send a private message To CS_Agent
