08-03-2026
01:22 PM
- last edited
4 weeks ago
Dunkman
08-04-2026 12:04 PM
hi @on2wheels
you can see that as they throw in the voice and text for free 🙂
honest, if only data is needed, better to get travel esim, it's usually cheaper of one time use
08-04-2026 12:02 PM
So there's no way for us to get only US data, we have to take the voice plan too. Another option is to use your reward points for those same amounts, 20 or 25 points.
08-03-2026 07:20 PM
PM is a prepaid service so you won’t be charge extra when your phone is on Roaming. But to connect in the USA, you need Roaming enabled so your phone will connect to AT&T, T-Mobile or Verizon network.
08-03-2026 01:48 PM
hi @Bapu they have different add-on for US
Talk and Text (15 days) - $15
Talk, Text and 5GB Data (15 days)- $30
Talk, Text and 5GB Data (30 days)- $40
08-03-2026 01:25 PM - edited 08-03-2026 01:28 PM
@Bapu wrote:How much does Public Mobile charge for USA roaming data.
Hello @Bapu
Here's a screenshot of prices. Depending how long you're going for, there may be better options.
If you're going for 2 weeks and need data, IMO, $30 for unlimited talk and text with 5GB of data is set poorly. You can upgrade your plan to $35 and get 25GB of data OR, if you don't want to lose your current plan, you can just purchase another SIM card or eSIM and get the $35 25GB plan. Then when you return to Canada, you just turn off autopay and the plan will expire on it's own after the 30 day cycle. Sure, you'd have a different phone number, but it's better value!
