Data
abdul0215
I need some data for today
Spudster
@abdul0215
Help us understand "need".
You could use free wifi to hold you over to the next renewal if it's a short time away.
Yeah if you have built up some points your add on could be cheaper
darlicious
@abdul0215
How much data do you need? What's your plan? Are you on the points program?
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
hairbag1
Log in to your account / Purchase Add-ons and find the in Canada data add-on you want. Make sure you put sufficient $$ in Available Funds...then buy your data add-on.
edit to add...
In Canada Data Add-Ons⁷
1 GB Data...$15
200 MB Data...$5
If you've ran you out, you'll need to do one of the following:
-buy a data add-on
-immediately change to a different plan (you will not receive any credit nor a refund for the unused portion of your current plan and plan payment for the new plan will be due immediately)
-renew your current plan early by making sure there is enough in your account balance and then asking a CSA to do this for you
