@ members
T_k
incoming/Outgoing not working.
SMS and data works.
@T_k   Please let us know what phone you have.
T_k
Did but nothing work.
Yummy
You mean calls do not work?
Try rebooting your phone (turn it off then on after a few seconds). Maybe removing SIM, cleaning contacts might make a difference? You never know...
hi @T_k
what phone do you have?
Telus is refarming all of their 850 to 10 MHz LTE B5 in their markets, mainly BC, AB, Windsor, Ottawa, GTA area Montreal, Quebec City.   Bell has not done this, so it won't affect area that has Bell networks which Telus/PM use
So, if your phone has only 850 Band 5 on the phone but lacks 1900 Mhz, if your phone were bought from another country, or an imported model, then you might be impacted
On the other hand,  if the phone has 1900 Mhz,  or it is a Canadian/US model,  it likely won't be impacted and won't see service degraded
https://www.publicmobile.ca/en/get-help/articles/850-turndown
@T_k  Maybe try and rebbot the phone or reset network settings . Can also try uninstall the messaging app and reinstall it see if that helps
