Data
Shasha1
My data is not connecting to my phone
8 REPLIES 8
Oh wow, that was alotta responses close together! 😂
If you have data left on your plan and other suggestions are not working, check your APN settings:
https://www.publicmobile.ca/en/on/get-help/articles?q=apn
HI @Shasha1   was data working on this phone before?
first try to reboot your phone and try again
Also, login to My Account and check if there is any data left from My Data & Add-Ons
If still not working, tell us what kind of phone you have
So that others may be able to provide you with valid suggestions, can you answer a few questions? Are you a new customer or are otherwise using a new device?  Has data ever worked or has it only stopped working recently?
@Shasha1  - ensure you have the data option selected to ON in the settings of your phone.
Try restarting it, or toggling into airplane mode.
You can also try to perform a reset of your device's network settings.
HALIMACS
@Shasha1
Did you just newly activate?
Are you out of data, check your My Data & Add-On section of your self-serve account.  If nothing showing there, you're out of data.
You can purchase more through the Purchase Add-On section.
You can also try manually switching your network to 3G if you're having data issues on the network.
@Shasha1
Try checking if Cellular Data is turned on. Go to your Settings under Cellular.
What phone are you using?
BeachNBeer
@Shasha1  Have you logged into your account to confirm you still have data left? Has your data ever worked? What did you try to get your data working? Reboot, turn on Airplane mode then turn off? What model phone do you have?
Shasha1
It is saying 3g network
