Thursday
Thursday
PM is on a 30 days cycle for your allotted data amount.
Same with Data Add-on. Expires in 30 days after the purchase date.
Thursday
hi @BLD2
what you meant ? your plan and data are every 30 days. If you buy extra data, the addon expires in 30 days
if you need to check data usage, then you will need to login My Account, and check usage log
