Data
06-01-2021 05:25 PM - edited 01-06-2022 02:13 AM
06-01-2021 06:49 PM
To add on to my last post, you can also select certain add-ons if you find yourself needed extra data, call minutes etc.
06-01-2021 06:47 PM - edited 06-01-2021 06:48 PM
It really depends on what your needs are. Obviously the cheaper the plan, the less that comes with it. I find that the $25 plan is a great in between. You get unlimited texting and calling plus some data for a very reasonable price.
06-01-2021 06:39 PM
@katiepoggio24 wrote:What is the best plan
Unlimited Calling and Unlimited Data.
Oh wait, that doesn't exist 😂
One great thing about Public Mobile is it is very easy to change plans whenever you want to change.
Need more data, schedule a plan change for your next renewal.
Don't need all the data in your current plan, schedule a plan change for your next renewal.
You can boost minutes or data Plans with addons that stay around until all used (will roll over month to month). But data addons can get expensive if you have to buy them all the time.
Options, you have options you can do, and change up as needed. 🙂
06-01-2021 06:24 PM
It really depends on your needs and usage.
If you does not really need your data and calls are minimal. $15 plan is likely the best plan everywhere
If you need unlimited calling and some data, $25 and $35 are very good plans indeed.
If you are high data usage date, PM might or might not be the best. You can also check Koodo and Telus plans which over even more data.
06-01-2021 05:29 PM
depends on you how much Data you need
all plan is very good.
welcome to public mobile
with a Beautiful Service
you will be very happy
Good Luck
06-01-2021 05:26 PM
@katiepoggio24 That depends on your needs/usage. Here are PM's plans:
