11-21-2016 08:31 PM - edited 01-05-2022 12:47 AM
I've now added 3 different iphones to PM and each of them required something different to get data working. I summarize here to hopefully help others in similar situations.
11-22-2016 07:02 AM
@Eug No I didn't try resetting the network settings on the phone. As for the reboot, since I turned off the phone to switch the sim card, I assume that is considered a reboot. Thanks for the comment.
@Luddite You are probably right. The unlockit.co.nz method would probably be required for iOS 7 regardless of phone. I was kind of making assumption that everyone is using the latest supported iOS for their phone.
@jdodd1079 I had similar issue with phone 2 which is why I needed to fill them in myself.
@caleblee123 Sounds like you have a different problem (incomplete port?). Everything I mention about data was after the fact that incoming/outgoing/text already working.
11-22-2016 04:57 AM
11-22-2016 12:47 AM
Does anyone have the issue with no incoming or outgoing calls and Data not working? I registered two days ago and its still not fixed 😕 Im using an iphone6 and i was with WIND before switching over
11-22-2016 12:44 AM
11-21-2016 10:17 PM
@MyzMc Slight modification: access unlockit.co.nz from Safari with phone connected on wifi.
Also I understand the issue is iOS 7 not specifically iPhone 4. So a 4s running iOS 7 has the same difficulty.
11-21-2016 09:06 PM
11-21-2016 08:39 PM
To add to your datapoints:
I have an unlocked iPhone 7. The only visible APN setting is for Personal Hotspot, but I did not have to change anything to get data working.
