DATA INFORMATION
05-17-2023
08:09 PM
05-17-2023
08:14 PM
computergeek541
05-17-2023 08:49 PM - edited 05-17-2023 08:52 PM
No need to apologize, @Jordanh20
This place isn't as intuitive as the creators may think it is.
To get more data there are a few of options:
- you can purchase a data add-on for $15 which gives you 1GB of data
- you can renew your cycle plan early by asking the Customer Support Agents to do this (you'd need to apply the funds necessary, which it sounds like you may have already...)
- you can change your plan to a comparable plan and choose to change plan now (this option forfeits what's remaining on your existing plan, and starts the cycle anew on the changed plan)
Any of these options are dependent on how much data you need, and for how long.
You mentioned you're only 5 days from your next renewal --- perhaps try to utilize free Wi-Fi or other home internet connections in the interim (if available...)
Choice is entirely yours.
05-17-2023 08:34 PM
@Jordanh20 wrote:I performed a top up of 80.00. How do I purchase add ons with the 80.00. Sorry I am new to this. Appreciate you help
@Jordanh20 do you see $80 in the Available fund? you mentioned on your first post that you "bought more data", I hope you didn't buy US Roaming 1GB data, those are $20 each.
If you see $80 in Available Fund, you can go to Plan & Add-on page, click Shop Add-on or use this direct link:
https://selfserve.publicmobile.ca/en/account/manage/shop/addons
Then go to Data tab and buy either 1GB Add-on or 200 MB Data from there, Add to cart and complete the purchase
05-17-2023 08:26 PM
HI @Jordanh20
do you just want to buy data add-on ? or early renewal ?
if you are just short of 1GB or so, you can go to Plan & add-on page to buy 1GB
But if you need a lot more data, it is cheaper to start a new cycle now, but need to ask agent to help to early renewal
or you can do a Change Plan now to start a DIFFERENT plan for 30 days today. So, if the current plan does not have enough data for you every month, you can go with that.
05-17-2023 08:25 PM
05-17-2023 08:20 PM
05-17-2023 08:16 PM
I have tried to reset it twice already. And I have checked my data limit and it's disabled.
05-17-2023 08:14 PM - edited 05-17-2023 08:14 PM
Did you only perform a top up of $80 or was a data add-om purchased? Just adding money doesn't provide more data.
05-17-2023 08:11 PM
Clear cache. Try using incognito to reload the page or try another browser.
05-17-2023 08:11 PM
HI @Jordanh20
please try to reboot the phone once
make sure you don't have any data limit enabled on the phone
