06-01-2023 03:37 PM
Any downside of taking advantage of new promo, getting 5GB more data per month? Concern is losing all the promos I currently have (been a PM user since the start). Can I get a confirmation that nothing is lost by taking advantage of the new promo?
06-01-2023 08:21 PM - edited 06-01-2023 08:22 PM
@Ldo90 Yes that 6 points you get is a just for 12 months the $39 plan has no expiry … so for the first year your 15Gb for $40 plan is cheaper but after that year is up the $39 plan becalmed more valuable. In my opinion
06-01-2023 08:17 PM
do you know if the rewards promo from the $40/15GB plan still stands when you switch? I currently get 6 pts per month when I pay $40 but the $39 promo says you get 1.95 points for month so overall - it’s less rewards points?
06-01-2023 04:43 PM
06-01-2023 04:42 PM
So there is no downside? I guess I was confused about that disclaimer. If I get to keep my current reward program, then I will switch.
06-01-2023 04:35 PM
06-01-2023 04:33 PM
When I went to change to this plan it had this disclaimer:
Your new subscription will take effect on your next renewal date and you won’t be charged until then. This change replaces any other future-dated plan changes. After changing your plan, your current promotions will no longer be valid.
I'm on the original loyalty program and want to make sure I'm not switched to the new points system. Can anyone confirm what this part in red (above) means?
Thanks.
06-01-2023 04:18 PM
Also can confirm, I have retained all my rewards and promos from years passed.
06-01-2023 03:38 PM
@Winter_Squall no downside, just take it!!
Price is dropping. This $39 plan is in respond to other carriers' $39 plan. But limited time, so get it while you can
06-01-2023 03:38 PM - edited 06-01-2023 03:59 PM
@Winter_Squall Only if you consider saving money a down side I switched to this myself
Add So yes I can confirm !
