4 weeks ago
3 weeks ago
Just popping in to say that @Suboshi's method worked. I also changed to the $30 plan immediately, and this caused the special $35 deal to appear for me to transition to at the end of the new billing cycle.
I don't get why the plan is invisible to customers who already have more expensive plans. Just what was the thought process here?
4 weeks ago
Update: This plan is available for new and existing customers. However, if you have an existing plan already priced at $35/month or higher, you won’t be able to downgrade (thanks P!).
HOWEVER–there is a workaround if you’re willing to spend money or have credits. Downgrade instantly to the $30/20GB plan. Once that completes, upgrade to the $35/75GB plan instantly or at your next renewal date.
4 weeks ago
@ASaraswat - You can only switch to plans that show up when you try to change subscriptions. Usually, lower priced plans will not be available to you.
4 weeks ago
Is there a way to do the plan switch trick in order to get the $29 10GB Can US MEX plan? Currently on the $36 50GB Can US plan.
4 weeks ago
Thanks everyone, I was able to switch immediately, and then switch to the promo for next months billing period. Very pleased. Happy Holidays and New Years to you all. May others who need it find this post as well.
4 weeks ago
Tagging @Pat5747 for visibility. As indicated in those other two posts the switch worked for Suboshi.
4 weeks ago
Suboshi above just said that it worked. But yes, you would have to forfeit the $36 for this month.
4 weeks ago
Has one confirmed switching to $30 plan and back works? I foolishly switched plans for free my billing date was today, but not to the cheapest one and I am still only shown 40 45 and 50 plans. I'm at 36 now for 50gb and no us Mexico, I am debating paying forfeiting this months $36, and instantly paying $30 more to switch to the 20gb $30 plan and then upgrading to $35 with can usa mex if it will work.
4 weeks ago
ADD: I switched (immediate) to $30, then *WAS* able to switch to the $35 deal right afterwords.
Caveat -- I do have to wait a billing cycle for it to take effect though (without wasting more money.)
4 weeks ago
Does switching to the $30 plan (immediate) first, then scheduling for end of month *DEFINITELY* work? I assume you'd be stuck with the $30 plan for the first month if so?
Not attached to my number that much, so I guess cancel and sign up again (have an extra SIM already if needed) if not. Kind of stupid having to do it that way IMO.
4 weeks ago - last edited 4 weeks ago
You would have to do an immediate plan change to a plan cheaper than $35 for it to be available to select. Then you could schedule a switch to that plan for next month.
4 weeks ago
Promo offers are available to new customers only.
If you do not see plan you like when you log in to your PM account then it is NOT available to you and agent is not able to sell it to you.
