12-27-2024 06:36 PM
12-27-2024 06:41 PM
EZPZ...log in to your account on the app / Manage Subscription > Change Subscription...just select the one you want. You can opt to change now or change on renewal.
12-27-2024 06:41 PM
@Col42- Log into your self serve portal, or go into the app, and find the change subscription option. If you see the $19 plan, then you can change to it. Be sure to select the option to change at the next renewal date - so that you do not lose what you already paid for the current period.
12-27-2024 06:40 PM
Log in to your account, choose "Change subscription" and select a new plan from the self-serve menu. You can switch to any plan that appears for you.
