Outgoing Calls
DingoDan18
Recently, sporadically my phone wont dial out but I will receive all incoming calls. How can this be fixed, and what phone store deals with public mobile so I can go into a store to get them to help me.
10 REPLIES 10
GRHWAR
I have the same exact issue, everything works except for outgoing calls.
Their list says the A53 is compatible:
https://www.publicmobile.ca/en/get-help/articles/volte
DingoDan18
GalaxyA51 Android.
DingoDan18
Data works fine, texting sending and receiving works, I can receive calls, and when I. Make outgoing calls, 95% of the time it won't work for me.
DingoDan18
galaxy51 android
DingoDan18
GalaxyA51 Android
DingoDan18
I have galaxy A51 android
GRHWAR
What phone do you have?  I am having the same issue.  Public Mobile said my phone isn't compatible anymore.
sorry @DingoDan18  , no store help with PM, everything is online
so, does data work perfectly? was it just voice? do you still have some voice calls working or not at all in the last couple days?
what phone do you have?
i hope you are not impacted by this change:
https://www.publicmobile.ca/en/get-help/articles/850-turndown
NDesai
@DingoDan18 What happens when you dial out a number with or without +1 in front? Can anyone else in the same area dial the same number successfully?
will13am
@DingoDan18 , Public Mobile does not have any physical stores.  It is a totally online service.  What model of phone are you using?  If your phone is older, this help article could explain your issue as calls might still be on the 3G network.
