04-11-2020 09:42 AM - edited 01-05-2022 10:19 AM
HI All
Next month we have to drive from Ontario to BC. We have driven across with other cell providers - Telus - and know that PM is a secondary carrier.
I'd like to know if there are any KNOWN blank areas of coverage travelling on the Trans Canada.
Is that for phone service or just data?
This will be our only form of communication for a couple of weeks.
Thank you
04-20-2020 10:02 PM - edited 04-20-2020 10:02 PM
@brettster99 Telus and Bell do not roam onto each other's networks. They share the radio access, and use their own cores. Roaming is when you are connected to another operator's core.
04-20-2020 07:59 PM
Considering as you know Public mobile is under Telus it’s the same coverage as Telus. It may change to Bell (Won’t say Bell think it will just say roaming but could be mistaken) if Telus does have an UNKNOWN blank spot.
Doubtful but possible. The bars for connectivity mean for both data and phone and text so keep that in mind but I’m sure you will be fine
04-19-2020 11:56 AM
@ladybearbc other than north-western Ontario where Rogers/Tbaytel is stronger, you will have excellent coverage with PM.
PM users cannot roam on other domestic networks for regular service, but you can always make a 911 call on any network.
04-19-2020 09:24 AM
@ladybearbc Telus/bell have set up coverage that parallels the transCanada and major highways. You might get the odd blip in the mountains and if you take the coquihalla between Merritt and Hope there's about an hour or so section that has no coverage. Everywhere else is pretty good.
04-19-2020 08:32 AM
Here's a coverage map that you can use to check for any blind spots.
04-19-2020 07:56 AM
Thank you
04-11-2020 12:30 PM
Thank you - we noticed there is a different carrier up there a few years ago when we travelled it - and apparently you can't even use the phone for 911 on their network.
Has that changed?
04-11-2020 10:26 AM
@will13am wrote:
@Anonymous wrote:
@will13am wrote:@ladybearbc , I have done this route many times. I assume you are taking the highway 17 across northern Ontario. Coverage is spotty west of Sault Ste Marie until you get to Thunder Bay. Tbaytel provides the best coverage up north but even their service has coverage holes. It is difficult to have a signal along a zig zagging highway that is cut through rock.
And then you hit the mountains. It is difficult to have a signal along valleys and passes.
Maybe it is the duration without signal, I hardly notice that much lost coverage going over the mountains. It is a 7 hour drive between Soo and TBay. There are hour long stretches with no signal. There are far more moose than cell towers lol.
I see that on the coverage map. And then solid everything from TBay to the mountains. And then it's highway corridors in valleys and blobs of larger centres.
04-11-2020 10:21 AM
When you look at the coverage area here:
This shows all the coverage of their cell towers. This would be coverage for their complete service not just text and call but data as well.
That is just looking at it from an analytical point of view. But, someone may have insight that has travelled them parts..lol
Have a great day!
04-11-2020 10:19 AM
04-11-2020 10:10 AM
04-11-2020 10:07 AM - edited 04-11-2020 10:08 AM
@ladybearbc , I have done this route many times. I assume you are taking the highway 17 across northern Ontario. Coverage is very spotty on the Bellus network west of Sault Ste Marie until you get to Thunder Bay. Tbaytel provides the best coverage up north but even their service has coverage holes. It is difficult to have a signal along a zig zagging highway that is cut through rock.
04-11-2020 09:45 AM - edited 04-11-2020 09:46 AM
@ladybearbc PM is owned by Telus and runs on the same network. So if it worked without any problems using Telus. Then you shouldn't have any problems using PM. Stay safe.
04-11-2020 09:45 AM
Coverage should be good as PM uses Bell and Telus towers. Here is a coverage map.
04-11-2020 09:45 AM - edited 04-11-2020 09:45 AM
@ladybearbc You are on the same network as Telus and bell you should have no problems on the TransCanada
