11-06-2024 04:50 PM
We go south for the winter ( US ) rather than putting a “ Add On “ to our subscription is there a plan that allows us to have US Calling within the US at all times. We use very little data and would only use for the odd call. I find it confusing that there appears to be several plans and yet to have the service as mentioned above it states that we have to have the 15 day “ Add On “ Thank you
11-08-2024 09:01 AM
If you are on a relatively cheaper plan, be very careful of opting for a high $ plan only to accommodate US Roaming.
Telus/PublicMobile is using deceptive tactic where they won't warn you at the time of plan change that you'll henceforth be losing access to cheaper plans forever, in your self-serve.
11-06-2024 05:14 PM
Thank you for your help…much appreciated
11-06-2024 05:06 PM - edited 11-06-2024 05:06 PM
hi @Roots2
yes, tax on top,
when you want to make the change, go to your My Account, pick the plan you want and click Change on Renewal to schedule a plan change
11-06-2024 05:04 PM
Thank you just one question is the $30.00 for 20GB of data my Total monthly charge excluding taxes of course.
11-06-2024 04:54 PM - edited 11-06-2024 04:54 PM
@Roots2 Yes and plan that says CAN/US has roaming built into it and you can use in both country s to call to and from either country talk data and text . But if you change plans you might not be able to get your old plan back again . But with CAN/US plan there’s no need to buy US roaming add on .
11-06-2024 04:52 PM - edited 11-06-2024 04:55 PM
hi @Roots2
yes, there are many Canada-US plans for everyone now. what amount of data you need?
Get the Canada-US plans, it is better and cheaper , especially for you who go US for months
here are the choices:
$30 - 20GB
$35-50GB
$45 - 65GB
