3 weeks ago
3 weeks ago
if you are using app, you need to go to Account page, Mange Profile to update the postal code
if using browser, then go to Profile page,and choose Mange EverSafe ID
3 weeks ago
@KhadidjaTB wrote:How I can update my postal address on my account?
While the option does exist to change the address, the address isn't actually used for anythying.
3 weeks ago
@KhadidjaTB wrote:Hello,
Thank you
Just so you know @KhadidjaTB it actually doesn't matter what address or postal code you use with Public Mobile as they will never mail you anything via Canada Post. Everything is done through email services.
3 weeks ago
hi @KhadidjaTB login to My Account first, go to Profile , Manage EverSafe ID and you can update the address and portal code there
